Battery Fire!!! Please Help! 1999 A6 quattro
Old 10-13-2013 | 07:31 PM
lianne_m_jones's Avatar
Default Battery Fire!!! Please Help! 1999 A6 quattro
Hi there,
I am new to this site and need to see if someone can help me with my after battery fire 1999 Audi A6 Quattro.
So here goes.
My audi battery caught on fire. Seems the metal rods underneath the back seat touched both the negative and positive terminals and the battery caught on fire.
The fire was put out sorta of quick all things considered.
The obvious damage:
Melted Battery
Melted insulation at battery terminal on cable
Melted green and yellow vacuum lines
Melted insulation on a black wire
Repairs thus far:
New Battery 5 yr Gold from auto zone
New insulation on battery cable at terminal location
Spliced green and yellow plastic vacuum lines
Re insulated black wire and reinstalled where it came from.
Replaced EUC
Now:
The car is getting power from the battery
It turns over but sorta spits and sputters
It won't start
Fuel pump seems to be working (we can hear it working when our ear is on it, back seat burned up so everything is very exposed.)
Fuel is getting to the engine
The spark plugs seem to be getting power.
What else could have been damaged by this incident and what do you think I need to do in order to get it running again.
BTW it ran great before the fire. Thanks in advance. Metal Man if you read this I meant to thank you in advance also but didn't get it in my message to you before I hit send..(sorry, thanks to anyone who can help with this.)
It now seems it could be the fuel injectors. Did I blow a relay? Everything did sort of blow up when the battery overloaded and burst into flames.
Respectfully,
LiAnne
Old 10-15-2013 | 02:21 AM
MrFlippant's Avatar
I'm hardly an expert, but I would assume that shorting out the battery like that probably blew a few circuits. Start by checking all your fuses and relays and replace any that are burned or blown. After that, if there are still any issues I would pay the pros to sort it out, because tracking down and fixing electrical issues SUCKS.
Good luck!
Old 10-15-2013 | 09:37 AM
Default Hello
Hello and thank you,
We did check the fuses and they seemed to be fine. All other relays seem to be working however fuse 382 is the one connected to the fuel pump and supposedly to the injectors as well. We can hear the fuel pump working so I was assuming( I know *** out of you me) the relay was still ok. I guess I will replace that relay. I hope it's the right one..lol But yea, electrical,,arghhh..
For a girl I am becoming quite the a6 mechanic. Good thing I got that tool set last Christmas....lol...
I love my audi and want it back on the road!...But,, yes, it was quite the short out.
My advice to everyone with a battery under the seat, Make sure you have an insulated barrier between your battery and the seat! My will as soon as I get a new seat!
Thanks again,
Respectfully,
LiAnne
Old 10-15-2013 | 03:17 PM
Cool A6 won't start
Hello again,
Now I am being told that I may need to take the car to the dealership to have the key chip reprogrammed. Something about an immobilizer.
Does anyone know anything about this?
Thanks in advance.
planetnz
07-11-2013 03:15 AM
alternety
09-27-2012 08:22 PM
LesFex
06-11-2009 11:58 AM
gTT
10-05-2007 11:01 PM
