Air bag control module
RE: Air bag control module
if you have a problem with the SRS and you dont like it like me then remove the bulb from the dash ( if its on the system is disarmed ) and many cars have accidents where the airbags dont deploy which makes the unsafe or obsolete
Its under the center console, towards the front on an A6. If you take out the ash tray you should be able to see half of it. You have to pull the radio, a/c control head, ash tray, then un-bolt the entire center console and lift it up out of the way to get at the control module.
Does the entire center console need to be removed (including armrest)? I already removed the radio, climate control, ask tray and shifter cover but the control module is still too difficult to reach especially with the plastic air duct above it. Any extra info is helpful.
