AC Blower, wipers, headlights not working all of a sudden. Fuses ok, any ideas?
2000 A6 4.2L non turbo. I tried wiggling the ignition switch and I looked at all the fuses. I am perplexed as to why all of a sudden the headlights, wipers and ac-heater blower is not coming on. Car drives normal and starts just fine. Hazards blink and parking lights work. Radio works too!
Any ideas what else to check?
re
I read somewhere it could be a bad switch. But that doesn't make any sense to me. I removed the cover underneath the steering column, checked around and everything looks normal. I found some relays under there and some big fuses but they look new. Nothing burnt. How do you check the ignition switch? is there a changeable electronic part under there? If the switch was bad, will I need a new key and assembly? I don't know where to find a repair manual with this information in it.
From what I understand, there is two parts to the switch, the keyed lock and a contactor section. Pin 75 (yel/blk) supplies power to the headlights and would be a good place to check. I'm just going from wiring diagrams though..
Anyway, as always....thank you for your responses it really helped
It costs $70 plus shipping from ECS:
http://www.ecstuning.com/Audi-C5_A6-...itches/ES2172/
$65 seems like a deal
Glad you found it.
Glad you found it.
jfrish
12-06-2006 04:12 PM
