A6 unable to start the car every time I fill gas tank
I have a 1999 A6 that every time I fill the tank, the car wont start, jerks and stalls. Eventually the car starts and this does not happened until the next gas station visit.
RE: A6 unable to start the car every time I fill gas tank
I had a '99 A4 that did the same thing and eventually the check engine light came on. I took it in to the dealer and it ended up being the gas cap seal. They explained that the tank pressurizes itself and this seal needs ot be airtight. The seal is $1.50 but I spent over $100 diagnosing it.[:'(] Chane this seal before your next fillup and see if the problem still exists.
This happens to me too, at the gas pump and anytime I turn off the car and try to restart it within a few minutes it hesitates and has a hard time starting. It has never failed to start, and the gas pump is the only time it does it 100% of the time.
This is true....VAGCOM would shed some more light, but $1.50 is a quick fix and if the problem stops well then you saved some $$. VAGCOM would be the second step no doubt about it.
