a6 rim specs
Old 06-09-2009 | 07:44 PM
psychosnoman's Avatar
Default a6 rim specs
I have looked all over and found nothing. What is the off set on a 2001 a6 2.8? I'm looking to get new rims but don't know what to look for
Old 06-11-2009 | 04:17 PM
anybody???
Old 06-12-2009 | 02:24 AM
chefro's Avatar
Old 06-12-2009 | 11:02 AM
SloRide's Avatar
My A6 has a 45 mm offset. The center hub is 57.1 mm with a 5x112 bolt pattern. I recently got aftermarket wheels for mine and found out that I needed different wheel bolts. Audi rims use a ball seat style bolt and most aftermarket rims use the conical style bolt. ECS tuning had the bolts I needed. Also with aftermarket wheels because they are intended to fit a wide range of cars you need to know that the hub will fit. Many wheels can adapt using different hub centric rings to match the spicific center hub measurement, 57.1mm in the case of Audi's.
Old 06-14-2009 | 11:06 PM
thanks chefro
thanks sloride for clearing that up. i might be askin you later for more advice lol but thanks
p4sty
09-02-2010 01:17 PM
Ponch
Audi Q7
11-08-2009 05:48 PM
gino123
09-14-2006 07:42 AM
PhoneixFire13
03-06-2006 12:29 AM
Mass
02-25-2006 08:34 PM
