A6 limp mode after 10-15 mins driving local.
Old 12-03-2013 | 11:28 AM
Chypara's Avatar
Dovaking, are you sure your MAF sensor is good? I fix the problem just with replacing the sensor. And I had a same symptoms like you. But, anyway, yes, I can give you a TCM, just let me check the code.
Old 12-04-2013 | 02:33 PM
Dovaking's Avatar
Honestly I think it's not a got a code back P0507 idle air control system revolutions per min higher ?
An thanks tgat would really help me out my tcm # are
4BO 927 156 BS
I have a speed sensor problem too so idk if that cld cause a problem too but I'm doing a tranny flush soon
Old 02-07-2015 | 02:48 AM
justme123's Avatar
Default limp mode
Ok..so I just came across the same problem w/limp mode. Also the ABS and traction control came on. PRND432 were flashing. Reverse still worked RPM tack didn't work. I own an Audi A6 4.2L 2001. First there is one thing everyone should know. The TCM is located at the passenger side bellow the foot covering rest. Also the Audi has a problem with flooding below that area.. Which people forget to mention. I guess it never rains where there from. Saw it on YouTube. So I checked it and sure enough the TCM was waterlogged. Mind you it rained 3 months earlier..so I removed the TCM sure enough it was corroded. So I dried it cleaned it with 96% alcohol let dry..so far so good. Haven't found a solution to resolve the flooding yet. Still working on it. Check that first is easy to do and good luck.. don't forget to unplug the battery before removing the TCM
Old 04-10-2015 | 12:23 AM
Sirri's Avatar
Default Mr
Most of older model Audis has got a water problems that cause TCM goes bad. That happens when the hole in the Battery compartment front of the windshield is blocked. Take the battery out and clean the blocked hole.
peterbr1723
07-02-2012 08:48 AM
georger
09-28-2010 01:38 AM
ericp1.8T
04-28-2010 09:18 AM
NOMIND
07-21-2009 12:49 PM
auditt225
03-27-2007 04:32 PM
Quick Reply: A6 limp mode after 10-15 mins driving local.
