99 a6 p1545 p0300
99 a6 p1545 p0300
I have a 99 A6 2.8. I replaced the timing belt and valve cover gaskets and now I get codes P1545, P0300,P0303,P0302. The car will start but barely runs and backfires slightly. Car was running fine before I started. What have I done? I do have the camshaft alignment tool and crank marking is right on the arrow.
Could I have messed up something with the fuel rail cyl 1-3 when I lifted it a bit to put remove the valve cover? Injectors are plugged in so it looks ok. I also cleaned out the PCV components, which is what started this nightmare,
It turns out the throttle module needed to be reprogrammed. I had the battery disconnected for a few weeks and the TM didnt reset. Lesson learned, if the repair manual doesnt tell you to disconnect the battery, don't do it! At least not for long periods of time.
