6 speed swap
RE: 6 speed swap
Just speculating, but here would be my guess:
Transmission
Flywheel and clutch
Throwout bearing
Clutch slave cylinder
Clutch master cylinder
Clutch line
pedal assembly
underdash wiring harness (clutch sensors for the cruise control, console display, lighting, etc.) Probably need to remove the dash to install.
center console
instrument cluster
possibly a driveshaft as the auto and manual may be different lengths
possibly a rear differential if the ratios are different
Cheaper by far to replace the torque converter then trade for a car witha manual. But that wouldn't be nearly as much "fun".
Good luck,
Bob
Transmission
Flywheel and clutch
Throwout bearing
Clutch line
pedal assembly
center console
instrument cluster
Good luck,
Bob
