2002 A6 xenon ballast
Old 10-13-2005 | 04:43 AM
markcauthen's Avatar
Default 2002 A6 xenon ballast
I have a bad ballast in one of my xenon headlamps. Can I replace this myself? It looks like I'll have to remove the whole headlamp assembly to get to it. Any advice?
Thanks,
Mark
Old 10-18-2005 | 09:46 PM
teddybgame's Avatar
Default RE: 2002 A6 xenon ballast
yes, see my links below for my OEM HID upgrade for background. Are you sure it is not the HID bulb? Have you tried a new bulb to troubleshoot?
You can get one from ebay for about $100. Just make sure it is from an A6 from 1998-2004 (an A4 or A8 won't be the same; any allroad ballast will work to). Here is exactly what you need:
http://cgi.ebay.com/ebaymotors/AUDI-...spagenameZWDVW
You can use the other wiring from your old ballas in it's place. Yes, you will need to remove the entire headlight to replace it.
Good luck!
Old 08-24-2010 | 03:54 AM
command's Avatar
Default 202 A6 oem Xenon Ballast
Thanks,
Mark
A6 oem ballast ,fit under the headlamp .ballast like this.
BTW AUDI RS6 use ballast is same
Old 10-19-2010 | 06:17 PM
AUDIFIELD's Avatar
Default ballast or bulb ?
hi I have the 98 qttro but I know it's xenon. my lights both work (high and low) but there is no blue tint. so is that bulb wear or ballast wear?
thanks! also what are the replacements I see for around 25 each on e-bay with new ballast?
thanks...
Old 11-19-2010 | 02:05 AM
command's Avatar
Default about bulb blue
thanks...
if you need bulb ,only need change the bulb ,choose 6000k is good.
like this.
Old 12-19-2010 | 03:08 PM
histeel's Avatar
you can replace this ballast without removing the headlight, you will need to remove the inner fender and remove the 1 screw that holds the ballast in place you will need to bend the bracket out of the way and slide the ballast out. It is a huge pain in the *** to remove the screw but it is a lot easier then putting the lock carrier in service position. This does work on the passenger side i have not tried it on the drivers side but it should work also you would need to remove the washer reservoir on the drivers side.
vasol
08-19-2013 03:49 AM
wutafobbb
B7 Models
05-16-2013 12:59 PM
jefferskn
03-25-2012 11:46 PM
tjaudi
B7 Models
04-08-2011 01:58 PM
BLAZEDUPBEE
01-05-2006 07:46 PM
