2001 headlight
2001 headlight
Hi, I managed to find a nice size pheasant a few weeks back... Only problem is it was with my car. Knocked the mounting tabs clear off the driver's side headlight. So now I need a new headlight. Any suggestions on where to find one? How do I know which one I need? Halogen? Xenon? I am not too experienced with these. I was also considering going this route if there isn't too much of a price difference between replacing the one for this set up... http://cgi.ebay.com/ebaymotors/02-03...item2c51d96443
Any experience? Thanks!
I need the driver's side assembly. I don't know whether or not it's the HID. Any way to tell? I know that the lights are pretty bright, clear, and a little whiter than others. I tried looking through the option codes in the trunk to figure it out, but can't quite read all of the codes. Thanks!
Non-HID will just have two 12v headlight bulbs (+turn signal) on each side.
You could post a pic...
I don't see a ballast (not that I'm 100% sure what one looks like), however I have a traditional looking light on the inside (nearest the grill) and a round, dome looking light on the outside (nearest the turn signal). I'm thinking it is probably the Halogen. Is this a correct assumption? Thanks for all of the help!
