2.8 hard start when cold (20 degrees) then runs fine
Old 01-06-2010 | 05:59 PM
felixvg's Avatar
Default 2.8 hard start when cold (20 degrees) then runs fine
Help. I garaged my S6 for the winter when I found a 99 2.8L avant,
When it is below 20, it takes about 15 trys to get it going, As soon as it starts, it runs perfect, Then if it sits for 8 hours. same problem
New plugs, and has thrown no codes.???
Any ideas?/
TIA
Old 01-06-2010 | 11:43 PM
maxim_s45's Avatar
any errors regarding sensors appearing when you try to start it?
I had a rare problem with G40 sensor - camshaft position on 2.8 AAH. No errors when you get it running, but when you try you rarely can see this in VAG com.
Old 01-07-2010 | 12:52 AM
Jeffla's Avatar
coolant temp sensor, maybe a vacuum leak.
Coolant temps sensors don't seem to set error codes.
Old 01-07-2010 | 08:35 AM
maxim_s45's Avatar
I was not talking about coolant sensors...
Old 01-07-2010 | 02:07 PM
chefro's Avatar
starter woes?
dvdvsx52
11-11-2015 02:09 AM
dvdvsx52
04-13-2015 04:28 PM
Prokon
10-25-2007 04:06 PM
Phaedrus44
08-16-2007 04:03 PM
