2.7t major coolant leak, not the aux pump
Help, trying to fix my sister-in-law's 2.7t.
I've now torn down the engine to the aux pump, leak isn't there. The leak is so sever that the fluid pours out almost real-time as I pour it in the reservoir. It seems to be coming from the passenger side and if I jack it up and watch it leak as I pour, it runs down through the alternator, so it's coming from near there.
Any ideas?
Any ideas?
i need help my wife was driving my audi A4 quattro 2.8 and there was a big water leak under the car..I can see where it comes out from there is no water in the reservoir tank.. there is no leak inside the car just out side any help Please...Thank you
There's a coolant flange and ECT sensor on the back of the engine on the 2.7t near the passenger side. It's best seen while standing right by the passenger side wheel well, just past the kombi valve. Check to see if that is broken / leaking.
thanks nebuchadnezzar, Unfortunately I think I found the problem, and I don't think it's that simple. There is a large plastic part on the front of the engine, behind the timing belt on the passenger side that is cracked. This is where the coolant is exiting the engine, I assume this happened from too much water in the coolant over a Utah winter. Can anyone tell me what this part is and if I can replace it myself assuming I had the knowhow to get to here? Also does this kind of damage on this part point to possible other damage internally?
Yup. Thermostat housing. You might as well put a new thermostat in there, as well as the thermostat o -ring as well since it'll be off.
Although I've never tried it, I'm willing to bet you can probably wiggle the housing out from behind the timing belt without taking it off, thus taking care of any headaches associated with a timing belt job.
Though, that brings me to the next question: Have you had the timing belt done on this engine before? If not, now would obviously be a good time to do it since you've made it this far already. If it was done recently, then I would give it a go and see if it's possible to wiggle the thermostat housing out from behind the timing belt without removing it.
Cioffie
05-19-2013 10:24 PM
