1998 A6 Q ABS Brake Sensor Question
Old 01-06-2008 | 01:51 PM
patekatek's Avatar
Default 1998 A6 Q ABS Brake Sensor Question
I have been having problems with my ABS brakes for some time. I get an ABS pulsing when I come to a slow stop. Usually around 3-5 mph. After this continued for some time, the ABS light and Brake lights came on. I eventually had the ABS control module rebuilt and this got rid of the warning light issue and the pulsing at a slow stop. Then, a month or two ago I was driving in some very wet conditions and the pulsing during a slow stop returned. I'm getting a bit tired of this and I'm wonder if replacing the sensors at the brake/rotor area may fix this irritating situation. Is this a "do it yourself" operation?
I live in a more remote area on northern Minnesota and most local mechanics think an Audi is a belly-button that pokes out from a persons belly.
Thanks!
djClick here to upload!
Old 01-13-2008 | 03:10 PM
dankhound's Avatar
Default RE: 1998 A6 Q ABS Brake Sensor Question
Usually that problem is caused by a dirty or damaged toner ring on the axle not by the sensor itself. You may want to inspect the toner rings on the axle before you go replacing sensors.
CheckerBird
05-29-2015 09:11 PM
01quattro
08-31-2014 01:36 PM
whatisthat
04-12-2011 12:53 PM
ddd
12-19-2007 07:20 PM
bftlg
01-20-2007 07:34 PM
Quick Reply: 1998 A6 Q ABS Brake Sensor Question
