:: ECS Tuning :: ST Performance Coilovers for B8 Audi Sedan!
Changing the suspension setup on a refined German car often times feels like meddling with perfection. With an advanced, highly wrought coilover system, you can be confident your addition is a reliable improvement.
ST coilovers by KW are made of high grade, galvanized steel, and come with a 5 year limited warranty. With engineering tailored specifically to your Audi, preset dampening and height adjustability provide the perfect balance between performance and ride comfort.
Features include:
- Adjustable composite spring seats
- Tempered high strength springs
- Compression bump stop with integrated dust boot
- Hardened chrome piston rod
- Noise damping, corrosion resistant spring cap
- Galvanized Zinc plated strut housings for corrosion resistance
- All ST coilovers meet German TÜV standards
- 5 year limited warranty to the original purchaser
Looks good at any height.
Click HERE to order or for more information
Fits:
Audi B8 A4/A5/S4/S5 (2009+) Sedan
*Special Note* Audi vehicles equipped with Electronic Damping Control have front and rear OE dampers with electrically-operated actuators that change damping, on command.
Installing coilovers without similar actuators creates an open-circuit in the control harness to each of the four dampers; this change will turn on a dashboard warning light.
To prevent dash light illumination, a set of four resistors must be mounted and connected to the open harness plugs at each wheel. A complete set of circuit resistors is available from ECS Tuning (ES2608438) for installation with both KW and many other coilover kits. The resistors come with mounting brackets and exact-fit original equipment connectors. Adding them is a simple plug-and-play installation that will keep the dash light off.
Don't for get to check out our --------> Installation PDF <----------
Let me know if you have any questions.
Jason
ECS Tuning
02-10-2014 02:16 PM
ECS Tuning
B8 Models
02-05-2014 04:31 PM
ECS Tuning
02-05-2014 04:23 PM
