Sponsored by:
Sponsored by:
ZEX wet kit
Old 11-13-2005, 11:00 PM
VB05's Avatar
Default ZEX wet kit
alright so i was looking at the ZEX wet kit for fuel injected 6 cylinders. I see it comes with a module that sprays when it senses wide open throttle...which seems like a good idea...cause i mean when else would you spray. But having a manual...i have to wonder how quick it is to stop spraying as i shift. Cause i believe it is very bad to spray out of gear correct? (ie: nuetral, inbetween shifts)
Old 11-13-2005, 11:03 PM
Toff_the_Toffee's Avatar
Default RE: ZEX wet kit
If you get a wet setup, with a progressive controller, it works via your throttle settings. It gives full shot at full throttle, etc, and you can alter how much for your throttle position... JUST GET IT SET UP RIGHT!!!!!
Old 11-13-2005, 11:13 PM
VB05's Avatar
yea i kno, i would def have a reputable shop do it..not myself.
Old 11-13-2005, 11:16 PM
Railslider's Avatar
Yeah, NOS is crazy stuff if you don't do it right. You could easily melt your valves if you're not careful. Sounds like you've got the right idea having it installed.
Old 11-13-2005, 11:20 PM
VB05's Avatar
hah yea, they use that scary word that usually happens when its installed wrong..o what was that...o yea DETONATION [sm=nxsmile.gif]
Old 11-13-2005, 11:40 PM
Railslider's Avatar
Either way, you install it wrong and it's bad news bears. Haha. I imagine this system would be pretty damn good on a V6, you'll probably get some good response from it. They're usually pretty reliable too, I mean you can put ZEX on a ricer and not blow the engine up, don't see any reason why you'd ever have a problem with a well built Audi engine. I'd love to see what kind of numbers you're running with stock internals and ZEX. Or are you planning on changing cams as well?
Old 11-13-2005, 11:45 PM
VB05's Avatar
i'd probably run like 50-55 shot on stock internals (if i go for it) for awhile. If i didnt think that was enough then i would consider doing some internals so i could run more boost.
Old 11-14-2005, 12:07 AM
apg96's Avatar
I cnat wait to hear how it all works out. I have been thinking of it for a while. Maybe that and then a supercharger? For me the S/C would be first!
Old 11-14-2005, 12:10 AM
VB05's Avatar
i dont have the moola for a s/c, so thats why i am considering a ZEX kit. Granted that with a s/c would be a sick nasty 2.8!
EDIT: Plus I'm having major troubles with this place i ordered a remus catback from (www.autoaccessorystore.com do not buy from!!) So im gonna give em a call tomorrow and try and get my money back or something. Anyone know anything about that catback LLTEK sells for the 2.8?
Old 11-14-2005, 12:58 AM
VB05's Avatar
although apg....if i can get this EVO VIII, ill be doing mods to that and just leave my audi basically how it is to get to work, long drives, etc...
