YOU CAN BUY JUST THE BUSHINGS!!!
Old 03-14-2007 | 06:01 PM
Audi_Skydiver's Avatar
Default YOU CAN BUY JUST THE BUSHINGS!!!
Ok, so I clicked on the link above for the www.getcoolparts.com site and was looking around and found this:
http://www.getcoolparts.com/epcvsoap...d=getcoolparts
It says you can buy JUST the bushings and not the whole control arm!!! I thought you couldn't do that!?!?!?
What do you think?
Josh
Old 03-14-2007 | 06:07 PM
wood_e's Avatar
Default RE: YOU CAN BUY JUST THE BUSHINGS!!!
Sounds like a PITA to me...
Old 03-14-2007 | 06:14 PM
brrman's Avatar
yes - the reason Audi doesn't replace bushing is because it IS a pita... Easier to change the whole control arm.
Old 03-14-2007 | 06:18 PM
But what about the price difference. Is it really easier to change the whole control arm then only spend 6-10 bucks for a bushing?
Josh
Old 03-14-2007 | 06:20 PM
akielb's Avatar
the correct way to put it is - the cost (labor) to push out the bushing and put the new on in is greater than just replacing the whole thing.
Edit: cheaper if you can do it yourself - but shop labor would eat the savings quick
Old 03-14-2007 | 06:22 PM
GEEZ!!! What do you have to do to get them out? And then back in again?
Josh
Old 03-14-2007 | 06:33 PM
victor_c's Avatar
I have changed mine before.
The dealer actually sell them too. cost me about 60 USD for lower front inner bushing.
it is an aluminum cylinder with aluminum core in the middle, suspended with rubber or something.
For my old one. the rubber is broken so it is very easy to take the core out.
I had to saw the cylinder on one side then take it out. It is much easier that way and it doesnt take long to saw off the aluminum.
putting the new one in is very simple. worst case.. use a vice.
Old 03-14-2007 | 06:40 PM
Yeah thats what I was thinking. My car makes a small clunk noise every time i go over a bump so I am thinking it's the bushings And I didn't want to spend a butt load of money on new control arms when it's just the bushings that need to be fixed/replaced.
Josh
Old 03-14-2007 | 06:51 PM
akielb's Avatar
Clunk = TRE
Old 03-14-2007 | 06:53 PM
Really? On my older audi (96 A4 2.8) I had a clunk and was told that so i replaced them and it didn't fix it.
Josh
