woundering what software i need for my 98 audi a4
MANIFOLD - STAINLESS 1.8L T3/T4 i have 440cc / 44lb fuel injectors / bosch green tops need to find out what software i need to use wit this set up
TURBO BRAND NEW IN THE BOX W/ WARRANTY
T3/T4 FLANGE .70 HOT SUPER SPOOL
38mm WG BRAND NEW
RFL BLOW OFF VALVE - BRAND NEW
GASKETS
FLANGE FOR BOV
FLANGE KIT FOR WASTEGATE
TURBO ACCESSORIES !!
INTERCOOLER
MANIFOLD INFO:
This manifold is drag-race quality, and similarly design manifolds can be found on professional drag cars.
Manifold has flange for an external wastegate. And since this manifold is tubular steel, it flows better than cheap cast iron
and is less prone to cracking. It was custom-made to be used with A 2 BOLT external wastegate.
TURBO INFO:
T3 TURBO INFO AUDI T4OE TURBO
3" INLET DIAMETER
3 V-BAND" OUTLET
WET FLOATING BEARINGS
1/8 NPT OIL INLET
.50 A/R .70 HOT
57 TRIM
SPECS:
STAGE IV WHEEL
BALANCED AND BLUEPRINTED AND COMPRESSION TESTED
38mm WG BRAND NEW
GASKETS
FLANGE FOR BOV
INTERCOOLER
MANIFOLD INFO:
TURBO INFO:
3" INLET DIAMETER
3 V-BAND" OUTLET
1/8 NPT OIL INLET
.50 A/R .70 HOT
57 TRIM
SPECS:
STAGE IV WHEEL
RE: woundering what software i need for my 98 audi a4
First off. I don't see that you have enough parts. This isn't a cheapy off of ebay is it? Generally you get what you pay for in turbochargers. You are going to need custom exhaust and exhaust flange to match the turbo, oil feed lines, and unless I missed it wastegate, and lots of tubing for the intercooler.
Good luck. If it is from ebay, I wouldn't waste anymore of your time or money. Chalk it up as one of those learning experiences. Ask questions before you buy and know what you are doing before you start buying stuff.
wasn't there another thread just like this? and yeah it looks like a cheap ebay kit and its a floating bearing turbo. you are gona give yourself a massive headache
well as far as i know giac chip will not work with t3/t4 turbo and i do have a custume exhaust with a test pipe and k&n i bought all the piping i need for the intercooler it also came wit all the oil lines gascets bov so i know when you do this type of up grade you ecu need to be reprogramed or you need a chip/ fuelmanagment system have a aftermarket d/v
