is this a woth it? $2300 1999 2.8 a4?
hello all. i have been looking into buying an audi and ran accross a 1999 audi 2.8 a4 quatro with 116000 miles on it. owner said it ran well but would need a timing belt service soon, a 4 wheel brake job, and the flashers and turn signals did not work. if the car has a good carfax history would it be worth buying? I am no stranger to turning a wrench but have never replaced a 2.8 timing belt before and was wondering how hard it would be.
RE: is this a woth it? $2300 1999 2.8 a4?
Have you seen it?
Have you driven it?
5-speed or Auto/Tip ?
If that's really all it needs, if the body/interior is good and it drives well, it's probably worth it. I would offer the 1500 and work from there. Depending on the actual condition of the car, you'll prob land closer to $2k. You should have $1500 ready to put into it after you buy it no matter what.
** If this is the price range of car you are looking for, the TB will HAVE TO BE CHANGED soon if not immediately anyway. THEY DO go BAD. It is a good starting point so you know for sure. For piece of mind if nothing else. Believe me, It's worth it.
Have you driven it?
ORIGINAL: freestyleski
and u can get rotors and pads for 400, and not sure about the turn signals, probably just burned bulbs.
that's a good buy if the car's in good condition. even more of a good buy if it's a 99.5.
timing belt service - $600 - $1200. They probably know this which is why it's listed so low.
4 wheel brake job - As long as the calipers aren't frozen, it's cake. 4 bolts hold each caliper on. The outer pad is held in place with a piece of wire and the inner pad has a clip on the back. Rotor has no bolts and is held in place by the rotor and wheel.
flashers and turn signals did not work - Hazard switch. About $35 from the dealer. Takes 10 min and only requires a pair of pliers.
Not a bad price at all.
Where are you stationed?
