woohoo got my first vag reading!!!
Old 06-06-2005 | 12:08 AM
pliddy's Avatar
Default woohoo got my first vag reading!!!
Chassis Type: 8D - Audi A4 B5
Scan: 01,02,03,08,15,17,25,35,45,55,56
Address 01 -------------------------------------------------------
Controller: 8D0 906 266 B
Component: 2,8l V6/2V MPI OBD2 D01
Coding: 01201
Shop #: WSC 06335
No fault code found.
Address 03 -------------------------------------------------------
Controller:
Note: Can't Synch Baud Rate
Address 08 -------------------------------------------------------
Controller: 8D0 820 043 H
Component: A4-KLIMAVOLLAUTOMAT_D65
Coding: 00162
Shop #: WSC 06335
2 Faults Found:
00603 - Footwell/defroster Flap Positioning Motor (V85)
41-00 - Blocked or No Voltage
01271 - Positioning Motor for Temperature Flap (V68)
Skipping Address 15-Airbags
Address 17 -------------------------------------------------------
Controller:
what does the baud rate error mean/?? most inprtantly, whats with my ac?? is that y my heat and ac are messed up? ac isnt working rite now...
plez help. thanks
Old 06-06-2005 | 12:16 AM
Jestnomen's Avatar
6th Gear
Default RE: woohoo got my first vag reading!!!
What interface are you using? Vag-com? Generic?
Try going to settings and turning FIFO off.
or
try this
http://forums.audiworld.com/a4/msgs/543453.phtml
Old 06-06-2005 | 12:34 AM
david9999's Avatar
You are missing a lot of readings. are you using a Vag-com or generic off eBay?
the HVAC codes show problems with the valves that direct air to your feet and the one that directs air over the a/c or heat. Taht will cause problems
00603
Footwell/Defroster Flap Motor V85
Blocks or de-energized /SP
- Short circuit, open circuit in wiring or incorrect terminal assignment (wires interchanged) of connectors between V85 and -E87-
- Footwell/defroster flap flap not operating freely
- -V85- inoperative
- Diagnose and repair short circuit, open circuit in wiring or confirm terminal assignment using wiring diagram
- Check for free operation of footwell/defroster flap
- Check -V85- using function 03 (Output DTM) Page 01-42
01271 4122
Temperature Regulator Flap Motor V68
/SP
- Short circuit, open circuit or incorrect terminal assignment (wires interchanged) of connectors between -V68- and -E87-
- Temperature flap sticking
- -V68- malfunction
circuit or confirm terminal assignment using wiring diagram
- Check for free operation of temperature flap
- Test -V68- using function 03 (Output DTM)
Page 01-42
Old 06-06-2005 | 12:36 AM
betz470's Avatar
Im a little confused about the vag-com stuff, can i just load the Softwear on my Laptop. Then connect the laptop to the car?
Old 06-06-2005 | 12:41 AM
david9999's Avatar
Yes and no.
You need the proper cable to connect your computer to the car. Generic cable can be bought from eBay for 40-60 bucks or so, but they have limited functionality, and often don't connect well. The free software you can get from Ross-tech is limited unless you buy the registered version for 100 dollars.
The Ross-tech cable and their full software costs about 230 dollars and comes with support. Worth the money for anyone with an Audi.
Old 06-06-2005 | 12:42 AM
Jestnomen's Avatar
6th Gear
That's typically how it's done.
Old 06-06-2005 | 12:48 AM
pliddy's Avatar
jest, im using an ebay cable and purchased the full software from ross tech...
so do i still do that FIFO thing?
thanks
Old 06-06-2005 | 12:49 AM
pliddy's Avatar
DAVID<
that must be reason y my ac dont work and heat comes out.. is this a self fixer upper? thanks
Old 06-06-2005 | 12:51 AM
Jestnomen's Avatar
6th Gear
it's a start. if that doesnt work then follow the link I posted.
Old 06-06-2005 | 12:59 AM
pliddy's Avatar
im using 311-2 . i dont think its the same interface..
