window vibrates loud when put down
Was wonderin if anyone has fixed the same problem. When i put my driverside window down it makes a loud noise like its catching on the lip of the door half way down then stops and is fine the rest of the way. Thanks for the help, Josh
RE: window vibrates loud when put down
You will probably have to remove the door panel to see what is obstructing it.
what year is your car?
For B5 on Audiworld:
http://forums.audiworld.com/a4/msgs/2366765.phtml
Wrax posted a good example for a B6 here:
https://www.audiforums.com/m_64080/m...l/tm.htm#64080
its just something rubbing against it...if u bought the car previously owned, the previous owner probably had some sub woofers in the trunk and bumped a lot with the windows a 1/4 of the way down and it caused something to vibraTE loose.
