Sponsored by:
Sponsored by:
Where is diverter valve in a4 b6?
Old 09-12-2007, 07:37 PM
TibZ's Avatar
Default Where is diverter valve in a4 b6?
Sorry this may be a stupid question, but I tried searching both in the forum and in the engine bay and I couldn't find the thing...Anyone have a diy or pictures of where the little bugger is?
Old 09-12-2007, 07:39 PM
cincyTT's Avatar
I'm make believe
Default RE: Where is diverter valve in a4 b6?
behind and just below the passenger side headlight. You have to get it from underneith the car
Old 09-13-2007, 12:06 AM
veloracer's Avatar
Good to know... as soon as I get chipped, I'm gonna put in a Forge 007. BTW, which is the best one to get for a B6? I see people on here running Forge and Stratmosphere.
Old 09-13-2007, 12:12 AM
cincyTT's Avatar
I'm make believe
the apr r1 there is no maintence or adjusting, so it is the simplest and since it is a diaphram, it is also the fastest
Old 09-13-2007, 07:18 AM
TibZ's Avatar
I actually bought a new Neotek BV18T for $50 from another member...it only has the one spring so I'm unsure whether to put it on before I chip...
Old 09-13-2007, 10:32 AM
fumoazul99's Avatar
is there any difference in performance if you replace the dv even if you aren't chipped?
Old 09-13-2007, 10:34 AM
onepoint8tee's Avatar
ORIGINAL: fumoazul99
Only if your stock one is bad.
Old 09-13-2007, 10:36 AM
Bondga's Avatar
ORIGINAL: onepoint8tee
or if the one you put in is set to high for the boost your running
Old 09-13-2007, 11:19 AM
fumoazul99's Avatar
*stupid question*
How do you know if you DV is bad?
Old 09-13-2007, 11:20 AM
Bondga's Avatar
if it dosent work!!!!
Quick Reply: Where is diverter valve in a4 b6?
