Sponsored by:
Sponsored by:
when should the timing belt be changed?
Old 12-17-2007, 11:14 PM
loktian's Avatar
Default when should the timing belt be changed?
when should the timing belt be changed for A4?
i got a '04 A4 at 120km... ( i cant believe its that much myself)
so i was wondering when is the timing belt due for replace?
thanks thanks!!
Old 12-17-2007, 11:18 PM
S_R_N83's Avatar
Default RE: when should the timing belt be changed?
already past due
Old 12-17-2007, 11:19 PM
onepoint8tee's Avatar
Do it now. Its not overdue, if Im not mistaken 120 km = about 75k miles which is a safe time.
loktian's Avatar
shoot.....so the best is......right the ****now...ye?
Old 12-17-2007, 11:46 PM
You could probably go a while longer, but, the sooner the better.
Old 12-18-2007, 12:08 AM
loktian's Avatar
yo~ thanks for replying!
Old 12-18-2007, 12:54 AM
nordska's Avatar
i just did mine and the belt was in pretty bad shape.... @ 87K... i wouldnt wait to much longer, its not worth the risk of it skipping/snapping.
Old 12-18-2007, 04:05 AM
littleflavio's Avatar
i had mine change around 92k miles and when i saw the belt with my own eyes it has some cracks already and my water pump was freezing when u roll the bearings. a week more run and its gana snap. urs is preet safe but i would reccomend for u to have it change now. also change the water pump, tensioner, idler roller etc...u can buy the whole kit at ecstuning.com or i think mjmautohaus is selling it cheaper. i had mine from ecs no problems whatsoever
Old 12-18-2007, 09:00 AM
Papachristou's Avatar
its not past due but its getting on time, 75-80k is the safe time to change it, i think audi recommends 90-100k
i am at 75k as well and just got my kit in... just havent decided when to tackle it.... got mine from www.purems.com.. cheaper than ecs...
Old 12-18-2007, 11:14 AM
RedShoeRider's Avatar
Add one more voice to the chorus.....it's time you got down and dirty with the timing belt. And water pump. And everything else under those covers. I just did the A4 at about 90K miles, and while the belt wasn't horrifically worn, it was starting to show some signs of cracking. The belts lead a hard life. We can be nice to them
www.blauparts.com has a nice kit available as well.
Quick Reply: when should the timing belt be changed?
