when adjusting rebound....
Old 04-26-2006 | 11:29 PM
rons01a4's Avatar
Default when adjusting rebound....
on my koni coilovers, do i turn the alen key to the right to increase rebound? the second click should be 50%, right?
Old 04-27-2006 | 12:24 AM
trailboss's Avatar
Default RE: when adjusting rebound....
To increase rebound i believe it was 4 revolutions to complete stiff. 1 revolutin = 25% stiff 2 = 50% stiff 3 = 75% 4 = full stiff. You have to fully compress the strut to adjust it and you will feel when it is full stiff, it will hit a stop. Then you have to pull it back out and reasamble the upper mounting plate and so on. Use a bench vise to pull it back out.
Old 04-27-2006 | 12:25 AM
trailboss's Avatar
When they sent you the coil overs they send them at OEM settings. Using a stiffer spring the rebound should be increased, i sen mine at front 80% rear 90%.
adam044
08-02-2014 12:33 PM
nrowensby
06-04-2008 09:57 PM
rons01a4
03-28-2006 06:21 PM
jayA6
09-07-2005 02:07 AM
