Sponsored by:
Sponsored by:
Wheels~~Will they work? Please HELP!
Old 01-30-2008, 10:41 AM
Crunk's Avatar
Default Wheels~~Will they work? Please HELP!
I have a New set of Konig Wheels & Dunlop Tires......I need to know if they will fit on my 2004 A4 Cabriolet. The wheels in question are : 18 x 7.5 5/100/114.45B (offset 45)
Here's the problem..........
Discount Tire doesn't show theses as being a wheel for my car and I also called them and they said they wouldn't work. BUT Today I found the Same wheels on Wheelsnext.com and they are listed as being a wheel to fit my car with the Exception of them being 18 x 8..... Does the 1/2 inch really make that much difference?
Man I lovethose wheels and I had just bought them a Month before I totalled my RX8.
I Really want to know if there is some way I can use theses wheels.
Please Help!!
Old 01-30-2008, 10:43 AM
Bogie's Avatar
Default RE: Wheels~~Will they work? Please HELP!
check the hole pattern, measure your back spacing. try tirerack.com for that info. it shows up when you select a wheel and tire package.
Old 01-30-2008, 10:47 AM
Crunk's Avatar
They are 5 bolt Dual slot.... I was given the impression from Discount tire that they would not be good for the weight distyribution of the car...HUH?
Thanks for the website...I will double check there
Old 01-30-2008, 11:05 AM
Crunk's Avatar
FUCZK!!!!!
Looks like the Bolt Patterns specs for my car are 5-112
2Freakin' mm off!
Don't suppose they can be Machined?? Or is that a really stupid idea??
Old 01-30-2008, 02:30 PM
railrunner's Avatar
wouldn't do that.
keep looking. you will find some similar or another pattern you love. sorry to hear regardless.
Old 01-30-2008, 02:56 PM
Crunk's Avatar
Here is what I have...I can re-buy them again to fit the A4, But that SUX!!!!
http://www.discounttire.com/dtcs/fin...&tc=KONFUL
Old 01-30-2008, 06:07 PM
qUaTtRoA4's Avatar
you can buy an adaptor/spacer that will change your 5x112 on your car to a 5x100, a nice set of 4 would prolly ber about 200-250$
gl!
Old 01-30-2008, 06:22 PM
Crunk's Avatar
Thankies!
I will look into that.
I also called a Wheel Repair shop to see if they can change the both pattern 2mm.
Old 01-30-2008, 07:46 PM
khj677turbo's Avatar
your stuck on those wheels[:'(]
Old 01-30-2008, 09:59 PM
Crunk's Avatar
Maybe stuck with them...if I can't sell them
I know...I know, I do like the 2 tone wheels...not too flashy and not solid black.
Quick Reply: Wheels~~Will they work? Please HELP!
