wheel bearing replacement
Old 05-07-2007 | 04:03 AM
xcossx's Avatar
Default wheel bearing replacement
would i need to replace the whole hub to replace my wheel bearings? how tough of a job is this?
Old 05-07-2007 | 04:06 AM
SAudi's Avatar
Default RE: wheel bearing replacement
no you dont have to replace the hub, you do need a press though, do what i did with my rear wheel bearing, i just took off the upright and took it to a shop with a press and had it pressed for $20 alot better than the $175 i paid for someone to do it.
xcossx's Avatar
Default boost controllers... bad?
i wanted to up my boost to around 9 or 10psi with my stock turbo.... i was thinking about just getting a manual boost controller... would that **** everything up?
Old 05-07-2007 | 08:17 PM
nickellis14's Avatar
Default RE: boost controllers... bad?
would most likely throw a CEL at you. I could be wrong, but I doubt it. and depending onwhat you boost it too, you might be running a little leaner than you want to be. which is not good. don't want detonation in those cylinders! thats a BIG EXPENSIVE boo boo.
Old 05-07-2007 | 08:23 PM
chitownA4's Avatar
for my 02 b6 i replaced the rear left and the bearing comes as a whole piece with the hub from audi..
Old 05-08-2007 | 12:36 AM
akielb's Avatar
ORIGINAL: chitownA4
bet that was cheap
Old 05-08-2007 | 02:10 AM
chitownA4's Avatar
it wasnt too bad i paid like 130 or something like that for the hub..my friend works fora tech ataudi so he gets it cheaper..and i put in myself..that was a bitc#...but thats another story
Old 05-08-2007 | 03:42 PM
ironman's Avatar
I jsut did my front driver monday, 80 from ECS tuning OEM replacment and had family mechanic do it for me 80 part 80 labor all gravy. i was getting scared going over 80 as soon as i got on the highway to come home i was blazing 110 was nice feeling to go fast again.
Old 05-08-2007 | 04:07 PM
new2me's Avatar
ORIGINAL: xcossx
https://www.audiforums.com/m_477476/tm.htm
Dads Ride
11-11-2008 09:40 AM
mhellman
08-02-2008 02:44 PM
ImTheDevil
03-08-2008 04:40 PM
DjDiddles
01-10-2008 03:04 PM
chitownA4
09-14-2006 01:18 AM
