wheel bearing
RE: wheel bearing
I just did mine....
Tokk less than an hour to pull it out.
~70 for the bearing
~44 to have it pressed in.
To do it, you need a 14 mm hex, or whatever sixe the bolt is (if you have a the bolt head instead of the hex). 17 and 19mm wrenches/sockets. And I beleive it was a T-50 or 55 torx I used to remove the caliper.
It's actually really simple. Just make sure you disconnect the ABS sensor from under the rear seat and feed it through...you will break the old one if you try to remove it.
~70 for the bearing
RE: wheel bearing
My mechanic did it for 2 hours labour... I considered pulling the bearing, and just paying to have the new one pressed in... but I figured for 2 hours labour, at 45 an hour for my mechanic... I didn't have to lift a finger
Kyle_vdk
01-11-2014 10:25 PM
xqwizit
06-08-2009 01:27 PM
FACT
10-06-2007 04:54 AM
