Whats the diffrences in the 1.8ts
1.8t aeb and 1.8t atw what diffrence mounting? wiring? parts? dont car to much about internals or specs just what to know if both will work in the same car or what i have to change to make an aeb work in a atw car
RE: Whats the diffrences in the 1.8ts
AEB has 20 mm wrist pins for the pistons, ATW has 19mm.
ATW has secondary air injection, AEB doesn't.
ATW is throttle by wire where AEB is a standard throttle cable.
To swap an AEB into an ATW car you need-
AEB motor, the bottom end is the same with the exception of the wrist pin size
AEB wiring harness
AEB ECU
ndbw gas pedal
throttle cable
plus a few other things.
The motor mounts are the same. There may be a diference in the water pump also.
AEB wiring harness
AEB ECU
ndbw gas pedal
throttle cable
