View Poll Results: A poll
Bosch # 72174
0%
Big Boy Purolator L40316 # Mann W950/4
0%
Voters: 8. You may not vote on this poll
whats the best oil filter?
I have done some searching and I thought bring it to a poll... alot of people audi and vw have found using different filters (bigger) some oem with success...what do you use?
What oil filter and size do you use on your 1.8T A4?
We all want to avoid that nasty Mr. Sludge and the best oil pressure....
RE: whats the best oil filter?
Everyone is going to say the OEM dealer stuff, without any research or backing other than "it's what audi says". If Audi could design an engine that didn't cook (non-approved) synthetic oil, why listen?
I use the wix 51333 because of the added capacity and I got them for $5.50 each off fleetfilter.com. The 51333 (napa 1333) is the same equivalent of the Mann made purolator L40316.
In searching there seems to be alot of debate over flow rates and bypass valve pressure ...
here is a good link about it over in the B5 passat forum...
www.passatworld.com/forums/showthread.php?t=157542&page=2
if you use that one you should order them from autohausaz.com...they have them for only $5.45
not sure what the dealer charges you but probably more I suspect 1.8
A4 Jed
06-23-2013 06:13 PM
Nevalite
03-30-2010 12:13 PM
samleong
04-16-2009 09:16 PM
Niclipse
02-09-2009 01:39 AM
