Sponsored by:
Sponsored by:
What is this? and why is it dumping oil into my turbo?
Old 03-08-2007, 01:06 AM
Lazer Viking's Avatar
Default RE: What is this? and why is it dumping oil into my turbo?
ORIGINAL: ThePaintballGuy
Thats your DV valve!!!
Josh
good thing you know it isnt now.. for when you go and install a dv in the pcv valve location... that wouldnt have worked out well
Old 03-08-2007, 01:25 AM
A4Rollin's Avatar
man that would suck! especially when he turned the car on
Old 03-08-2007, 02:09 AM
The Bishop's Avatar
Or might it be that my turbo is spewing oil in all directions (it is going out on me) and getting sucked into the pcv and that's why it looks like it's coming from there. any thoughts? either way something is really F***ed up.
Old 03-08-2007, 02:15 AM
BaconBait's Avatar
ORIGINAL: thebishop
There's no way the turbo could spew oil out the inlet. It only goes in through the inlet and out through the outlet. Your motor would have to run backwards for that to happen.
Old 03-08-2007, 02:18 AM
The Bishop's Avatar
It's doin some pretty wierd things right now, so who knows it might actually be running backwards. It's in limp mode, and I'm getting pissed. Advance auto, and autozone scanners aren't being able to communicate with my car, and no one knows why. looks like it's goin into the shop.
Old 03-08-2007, 08:11 AM
AteUrV8's Avatar
lol pancake valve...
breakfast anyone?? Deluxe stack of pancakes with hot oil on top... mmm yummmy...
Old 03-08-2007, 12:33 PM
dafrazi's Avatar
Find someone with vag-com to scan your car before you head to the shop.
Also, a really dirty air filter can cause the engine to suck excessiveoil off the top of the valve train through the PCV system. This happens because the vacuum pressure from the engine can't suck enough air through the dirty airfilter and therefore will suck air andoil off the top of the valvetrain. Remember that our cars operate under vacuumthe majortiy of thetime that we drive them.
It's also pretty common to have a little wateraround the pancake valvedue to condensation.
  #18
Old 03-22-2007, 12:13 AM
akielb's Avatar
OK I know its been awhile but I found this part at ECS - they call it a pressure regulator valve - just go to ECStuning.com and search for "ES#7844" Cost is $25.69.
  #19
Old 03-22-2007, 10:04 AM
david9999's Avatar
Just dump the oil out of the PCV valve and put it back.
IAmRain
08-05-2015 07:45 AM
andrewzpsu
11-29-2010 12:52 PM
Indiepunk
09-29-2007 06:27 PM
Quick Reply: What is this? and why is it dumping oil into my turbo?
