WHAT is up with this Time Slip????
Hey guys, i was looking through the time slips on this site and i found this https://www.audiforums.com/timeslips...?TimeSlipID=37
I was wonder how in the hell he was running that much boost from the S/C and the No2 on the 2.8L engine because i have herd that the 2.8 can not handle that much boost at all. I am intrested in how this guys is gettin that much hp outta his 2.8. I realize the numbers may be 'messed with' cause every body likes to look good.
(I know this might be better for scaudi.com) but while im at it, does any one here run a higher boost than what the PES S/C gives you? Any body with Water / Menthanol Injection running the PES S/C?
Anybody know what this guy did to get 35psi? Because he wont except PM's witch only makes it look less 'la-git'... [sm=rolleyes.gif]
RE: WHAT is up with this Time Slip????
if you all look a little closer he is also running nitrous, supercharged and a 75 would more than definatley get you the numbers he is claiming to have. Dont know for sure but it at least makes his story a bit more believeable.
ORIGINAL: sdboarder84
