What part # is this hose?
http://i126.photobucket.com/albums/p...a/P7170430.jpg
The pic is not the clearest but its the hose on the right and the elbow coming off the intake that have cracks in them.
RE: What part # is this hose?
Its the main vac source that supplies the brake booster among other things
activated carbon filter system / vacuum system / throttle valve control unit / F 8D-W-104 601>>*
/ AHL
06B133213[/align][/align]
variable intake manifold
06B133619B[/align][/align]
drive unit
06B198619A[/align][/align]
repair kit / drive unit
MANN+HUMMEL /
06B133200[/align][/align]
intake manifold - lower part
06B129717A[/align][/align]
gasket
06B133299A[/align][/align]
coupling piece
06B133301A[/align][/align]
clamp
53X7X0,6 /
058133557[/align][/align]
seal
9
058133063H[/align][/align]
10
431121273B[/align][/align]
bonded rubber mounting
11
N 10092201[/align][/align]
allen key head bolt (combi)
M6X40 /
12
058905291A[/align][/align]
non-return valve
13
431820667[/align][/align]
grommet
14
037906283A[/align][/align]
solenoid valve
15
058133212B[/align][/align]
cover
16
058133212A[/align][/align]
cover
17
058133479A[/align][/align]
torx socket head panel screw
DG60X20 /
N 0203535[/align][/align]
hose in coils of 5m 'order unit 5' / shorten to: / shorten to:
3,5X2 100MM 150MM /
N 90080102[/align][/align]
hose in coils of 5m 'order unit 5' / shorten to: / shorten to: / shorten to:
7,5X3 130MM 50MM 155MM /
23
06B129723N[/align][/align]
support
front /
24
06B129723P[/align][/align]
support
rear /
25
N 10063202[/align][/align]
hexagon head bolt c/w shoulder
M8X20 /
26
N 10340101[/align][/align]
hexagon nut, shouldered
M8 /
27
06B133354[/align][/align]
intake air duct
28
N 90316802[/align][/align]
round seal
19,6X3,6 /
29
032121142[/align][/align]
retaining spring
30
N 0245183[/align][/align]
pipe clip
AL70-90 /
31
N 01508311[/align][/align]
M8 /
32
06B133784A[/align][/align]
angled hose
33
06B133784[/align][/align]
angled hose
34
06B133382[/align][/align]
t-piece
8/8/8 /
36
N 90424201[/align][/align]
allen key head bolt
M8X45 /
37
N 10233401[/align][/align]
spring clip
16,2X7X0,6 /
38
050133787[/align][/align]
connecting pipe
39
058133459[/align][/align]
support ring
40
058133517[/align][/align]
solenoid valve
41
058133784[/align][/align]
reducer hose
42
N 90666101[/align][/align]
cable tie
4,5X200 /
43
8D0971897B[/align][/align]
cable holder
44
050133095D[/align][/align]
retainer / see illustration:
201-95 /
46
171201981[/align][/align]
/ AHL
drive unit
MANN+HUMMEL /
gasket
coupling piece
clamp
53X7X0,6 /
seal
9
10
11
M6X40 /
12
non-return valve
13
grommet
14
solenoid valve
15
cover
16
cover
17
DG60X20 /
3,5X2 100MM 150MM /
23
support
front /
24
support
rear /
25
M8X20 /
26
M8 /
27
intake air duct
28
round seal
19,6X3,6 /
29
retaining spring
30
pipe clip
AL70-90 /
31
M8 /
32
angled hose
33
angled hose
34
t-piece
8/8/8 /
36
allen key head bolt
M8X45 /
37
spring clip
16,2X7X0,6 /
38
connecting pipe
39
support ring
40
solenoid valve
41
reducer hose
42
cable tie
4,5X200 /
43
cable holder
44
201-95 /
46
im not seeing anything specific. If you go to audi/vw they will most likely charge you $50-75 for the hoses. I think you can find simular stuff in the help section at a parts store.
DiscoJaker
12-02-2020 02:16 AM
