What is this part called?
Hi All,
This part fell off from the front of the car today. As the pic depicts, it is the plastic part (cover) right under the fog lights. My questions are:
1) What is this part called? (Is it belly pan?)
2) Should I try mounting it back with zip lockers etc? or should I get a replacement?
3) If I need a replacement, where is the best place to get it?
Thanks in advance.
ps: http://img48.imageshack.us/my.php?image=40rc0.jpg (in case the pic doesn't work here)
Thanks in advance.
RE: What is this part called?
its called the lower valance. held in by clips and then 2 screws by the the fenders. mine has fallen off a couple times and i have it held in with black zipties (not noticeable unless you look for it) and new self-tapping screws by the fender liner. Likei said it can be remounted with fairly good results. Mine has fallen off twice after i remounted it but that was because it was too low for a curb/ramp into a gas station. a repleacement can be bought from ecstuning.com for like $60 i think.
keeps debris away from your motor and slows squirrels from attacking your oil pan as you hit them..... most people just take it off
ORIGINAL: SMoLiK
What purpose does it serve?
SMo'
SMo'
ORIGINAL: BadLuckAudi
but anyways, its just part of the bumper, you don't need to understand it anymore than that
where to get it-
www.ecstuning.com-search ES#5538
ORIGINAL: sean1.8t
really? who would these people you are referring to be?
where to get it-
where to get it-
BadLuckAudi - Thanks for the reply... I figured it had something to do with proper cooling, or aerodynamics/handling (keeping a low pressure zone under the car) but keeping crap from kicking up under the car is just as important... Thanks bro...
SMo'
lol.... mine has fallen off twice and its been at the worst times, but its pretty easy to put back on, and even easier to take off, but than you dont have any protection against dirt or squirrels or anything else badluckaudi can think of
ORIGINAL: SMoLiK
Gee thanks for the excellent input! Next time I want a stupid answer that gets me no where I will be sure to just PM you directly!
SMo'
ORIGINAL: sean1.8t
where to get it-
where to get it-
SMo'
ORIGINAL: sean1.8t
umm, ok i only told you exactly where to get a cheap brand new one but whatever.. if you can't take a look at it and realize from common sense that is is part of the styling/cooling/protection (or even figure out one of those)of the car and enginethen you sir are the stupid one.. i mean come on, use your head
ORIGINAL: SMoLiK
SMo'
ORIGINAL: sean1.8t
where to get it-
where to get it-
SMo'
SMo'
