What the Heck? Hidden EQ
RE: What the Heck? Hidden EQ
only for symphony radios
and here's the directions
here is the trick to unlocking the "secret EQ"
To access the EQ all you have to do is turn off your car and remove the key. Then hold down the number '5' on your CD changer/Radio preset control and power on the head unit.
You will see '55555555' if your radio is in stock form. These numbers represent 4 EQ settings each for front and back. They are, in order from left to right (courtesy of LCP on the AudiWorld forums):
1. Front low bass
2. Front mid bass
3. Front midrange
4. Front treble
5. Rear low bass
6. Rear mid bass
7. Rear midrange
8. Rear treble
To adjust the settings, use your volume **** to change the flashing digit to a value from 1 to 9 (1 being the lowest level, 9 being the highest) and press P.SCAN to go to the next digit. When you get to the end it will wrap back to the first digit.
1. Front low bass
2. Front mid bass
3. Front midrange
4. Front treble
5. Rear low bass
6. Rear mid bass
7. Rear midrange
8. Rear treble
#19
Has anyone tried using the popular set up that was referenced above? If I could get mine to sound even better, I would be amazed. The Bose Symphony has to be the best stock stereo system I have had. I've had people comment on it when they ride in my car too. Only thing I would change is maybe adding a 10 inch sub and that's it.
