what else do i need with a 2871rs
RE: what else do i need with a 2871rs
hopefully you have a 1.8T....the year would definately be helpful....dbw/ndbw?
ummm....start *HERE*
save questions like this until after you have thoroughly searched the forum...
there is a link for the search function above....welcome and good luck!
for future notice, you will want to provide all info about your car prior to asking any questions about it
if you get that kit just remember you have to upgrade basically everything. I highly recommend a manual boost controller also so you dont blow a rod through the block like I did. I had to learn the hard way. Had a ATP GT3071R turbo kit installed and had all the right goodies added except a MBC and one cold day I hammered it and POP!! I hit about 27psi on with a stock 1.8 motor. Oil was just pouring out. well 9,500 dollars later I learned my lesson. I also highley recommend forged rods and stronger pistons/crankshaft. Http://www.eurospecsport.com I would give that website a whurl as somethin to think about.
