weird noise in my car
Hey guys i just had my control arms and tie rods done, but havent have my car aligment done yet, i hear this weird sound like something rubbing against something and then when i go on curves, the sound completely goes away, could this be alignment or a bad wheel bearing.
thanks
thanks
RE: weird noise in my car
How is the noise while going above 50 miles an hour? Are you hearing this noise generally throughout the car, or is it like from the front or rear right side? Do you just hear a noise, or are their vibrations too?
the noise is like a humming sound, i think its from right rear side and goes away completely when i go right on turns and stays the same if i go left, i had my drivers side bearing replaced but i think its the passenger side bearing as i heard that they usually go out in pairs, what do u think it is
there is no vibration but the noise is frikkin annoying and increases as i go in higher speed.
thanks
and the noise starts as soon as i start driving my car.
thanks
To me it sounds like u have a wheel bearing problem. I found out i have the same problem 2 weeks ago. If you want to make sure that its a wheel bearing problem, go to walmart and get an alignment done there. It will cost you just about $20. If you still hear noises after the alignment, then its probably your wheel bearings.
