Water temp guage
Water temp guage
If I don't let the car warm for what I feel is a long time, the guage will never move. If I warm it, it works fine. I was told the sending unit is in the overflow. Is that true, I see what looks like it on the bottom and yes it has liquid in it. Is it the thrmostat? 99 `1/2 30v 2.8
RE: Water temp gauge
it doesnt sound like you have a problem really some temp gauges work like that, as long as the fan cuts in when its supposed to all should be ok also as long as heat is getting into the car is a good guide if no heat then there is a problem, if it ain't broke don't fix it
I had the same non issue on an older audi and I drove myself nuts with different thermostats and sensors. Finally decided to leave it alone and it was fine. A few weeks later, the fan switch went out. What are the odds?
zer0vette
07-21-2010 10:30 PM
