Voltage
Voltage
As the temperature is falling here in the NE, the voltage registered on the voltmeter seems to be rising. Now that the temp is 10 degrees, the voltmeter reads over 14V.
And no, I haven't gotten out my digital voltmeter to double check.
Anyone else have this going on? Don't know if I need to get a new voltage regulator.
thanks
thanks
RE: Voltage
Finally found specifications for the alternator. Up to 14.5 volts is within specifications for the Audi. Above that, the voltage regulator is likely failing. Mine reads 14.27V, so I'm OK.
Interestingly, I couldn't find the information in my Bentley, and had to go look in my Haynes manual.
