Sponsored by:
Sponsored by:
Valves tap on cold start
Old 12-22-2005, 09:12 PM
A4_Spooler's Avatar
Default RE: Valves tap on cold start
It was changed about a thousand miles ago, it doesn't happen at all at hot idle, just a few seconds on a cold startup, I used a 10w30 weight oil, should I cosider using a different weight?
Old 12-22-2005, 09:52 PM
onepoint8tee's Avatar
ORIGINAL: A4_Spooler
Well thats your problem, and i would guess you dont have the larger oem filter... So get 5w40 either mobil 1 or amasoil or whatever its called.. They are synthetic and the filter allows for better oil circulation..
Old 12-22-2005, 09:58 PM
AudiTech04's Avatar
ORIGINAL: JoeyZ
Same thing happens to my car. I dont like the sound. It "claps" on startup.
I have a 2004 3.0.....
This is how the 3.0s are, because the oil pressure drains out of the cam aduster and it is noisey till there is pressure
Nothing to worry about
Old 12-22-2005, 10:07 PM
ORIGINAL: AudiTech04
ORIGINAL: JoeyZ
Its a 1.8t.. The cam adjuster noise is different than the start up noise from the lifters isnt it? Besides that, Audi recomends 5w40 with the bigger oil filter to reduce sludge and improve circulation. Your cold lifters are gasping for some thinner oil to suck up....
Old 12-22-2005, 10:09 PM
AudiTech04's Avatar
Im aware that everybody else is talking about the 1.8 but that guy had a 3.0
whitneyj
02-28-2014 11:37 AM
B5 Audi
10-20-2010 06:28 PM
chusaiyan
01-25-2008 05:43 PM
rookie
12-06-2005 04:45 AM
mikea
12-23-2004 02:54 PM
Quick Reply: Valves tap on cold start
