Valve Gasket on 1.8T
Hi, guys My 1.8t is missfiring on hard drive RPM but no code, I pulled out the spark plugs to reduce the gap from 0.32 to 0.28 since it's chiped and I did found the Cyl #2 plug full of oil, I'm not an expert but looks like a blown valve gasket.
Is it expensive, any special tool and/or hard to DIY?
RE: Head Gasket on 1.8T
Are you sure what looks like oil isnt actually fuel? If you are missfireing there is unburnt fuel. I would swap the coil pack from the plug that is messed up and see if the problem follows that particular coil pack. Im surprised there is no code.
robert.jones
12-10-2008 08:01 AM
robert.jones
12-10-2008 07:56 AM
