VAG-COM won't connect.
RE: VAG-COM won't connect.
Dr Pooface Im still trying to get my VAg to work in the last 4 months , Ive tried 3 different
cables, 3 differnt USB converters now Im on my 4th cable which is a USB cable and I bought
a new Laptop as i broke my other one out of anger....
It kinda got me thinking why I love Audi So much, it makes my blood boil for all the wrong reasons
#18
These ebay cables do work, I use mine all the time for my A4 B6. You have to make sure the cable is the correct one (mine is "KKL Vag-Com for 409.1" (K-Line No CAN)), and you have to make sure to have the correct software from Ross-tech (mine is "VDS Lite Pre-2006 K-Line No CAN"). After this you plug your cable into your computer and go to "Device Manager" (for windows), look at your "Ports" menu, then right click on the correct device (this might start with something like "USB-SERIAL" (mine is "USB SERIAL CH340 COM3")) then go to properties and left click. Next go to the "Port Setting" tab and click on "Advanced...". At the bottom you will see "COM Port Number". This needs to be set to: COM1, COM2, COM3, or COM4. Choose one of those four options that isn't taken by something else. After you have set the COM port click okay and exit out. The cable can now communicate to your laptop.
Next, plug the cable into your car and then into your computer and turn the ignition to the on position. Open up Vag-Com and click on options, at the top left, set the COM Port to whichever COM (COM1,COM2,COM3,COM4) that you selected, then hit test. It will say "interface found" if everything is done correctly, hit "save" button. You will have to spend the $99.00 for the full software, but it will do some basic functions without purchase.
Hope this helps out, and thanks to everyone helping me out as well!
