UPDATE- CEL CODES POSTED~seafoam through vacuum line - CEL now
RE: seafoam through vacuum line - CEL now
Here ya go man.
http://www.audiworld.com/tech/eng.html
So how do I clear the code??? Do I just unhook the battery (positive cable)? I know that is how I have done it on previous cars, but I am not too familiar with Audi's.
So the light is off now......right before i hooked up the computer, the CEL went off; go figure. Anway, 7 codes still came up
p0300
p0301
p0303
p0102
p0300
p0301
p0303
I dont know why some repeated.....oh, and i cleared them after before I left. Also, when I pulled back to the house, I noticed I was still smoking...a tad from the exhaust and a good amount exhaust manifold. Anybody know how long it takes to burn that stuff off....it smells horrible.
p0300
p0301
p0303
p0102
p0300
p0301
p0303
wernt sure if you bumped this up becuase you didnt know the explanations to the codes...........
well,
p0300
http://wiki.ross-tech.com/index.php/16684/P0300/000768
p0301
http://wiki.ross-tech.com/index.php/16685/P0301/000769
p0303
http://wiki.ross-tech.com/index.php/16687/P0303/000771
p0102
http://wiki.ross-tech.com/index.php/16486/P0102/000258
and this is the website on the code list page.....
http://wiki.ross-tech.com/index.php/...ry:Fault_Codes
hope it helps
well,
p0300
p0301
p0303
p0102
hope it helps
P0300 the rest are for each plug P0301/2/3/4/5/6/7/8 and so on, take the spark plugs out and clean them and keep doing that till it burns off,
the seafom is probably sitting in the carbon cannister and will be released at intervals so as not to damage the cat it could take a while its basically doing the same as if the engine over fueled it will be stored in the C/cannistor,
I guess you put just a little too much sea foam in there
#18
Thanks for the link to ross tech. i changed the plugs before I went to Autozone actually, so all is good then. Also...that sputtering problem was fixed with the new plugs. Thanks guys.
Brautty
11-23-2011 09:20 AM
