Unorthodox Pulley Question
I was thinking about getting an unorthodox pulley for my 98 1.8T quattro and my question is will it be worth the power i gain? It costs about $200, and would it be worth the money? ALso about how much would it cost to get put in?
Thanks\
JOe
Thanks\
JOe
RE: Unorthodox Pulley Question
Im not sure on labor cost, but it is pretty much the same thing as replacing the timing belts. So if your almost due for a timing belt change around 60-70k then id do the underdrive pulleys then because it will save you money in labor. I want to recall that you have to use specific belts for the unorthodox pulleys, smaller than the OEM ones and i only remember seeing the pulleys for the v6 engines. I know ecs tuning makes the underdrive pulleys and includes all the necessary belts for like 190.
That depends on whose pulley you buy. But UNorthodox racing pullies are a good idea. See if you can purchase the 3 pulley set so you dont have to worry about over heating and losing charge on your battery. BUt yeah if your doing a timing belt change definatly change the snub mount and get pullies.
