Turn signals and parking flashers not working! Checked fuses and bulbs...
Old 03-30-2006 | 05:12 PM
datimez's Avatar
Default Turn signals and parking flashers not working! Checked fuses and bulbs...
I have a 1998 A4 Quattro 1.8T and the turn signals and the parking flashers aren't working. I checked and replaced all the fuses. It isn't the bulbs b/c when I use a turn signal or put the flashers on, nothing comes up at all on the dash (the turn signal lights) and also of course the turn signals don't work on the outside either. They were working and one day they all just stopped working altogether.
Please let me know if any of you all know what the problem could be and what I should check.
Thanks!
Old 03-30-2006 | 05:29 PM
brrman's Avatar
Default RE: Turn signals and parking flashers not working! Checked fuses and bulbs...
Hazard switch controls these things. Check to make sure it is hooked up. Might need a new one.
Old 03-30-2006 | 06:26 PM
datimez's Avatar
where is this hazard switch located at? and how do i check it?
Old 03-30-2006 | 06:29 PM
Jestnomen's Avatar
6th Gear
It's gotta be the hazard switch. You know the red triangle in the middle of the dash! All the relays are inside that thing. Time for a new one.
Old 03-30-2006 | 09:40 PM
datimez's Avatar
thanks for the help! i simply pulled out the hazard switch, dusted it off and put it back in and it works like a charm now!
TimTim7838
02-19-2013 05:53 PM
Ramathorn
07-14-2012 11:02 AM
WintonA4
10-02-2010 04:26 PM
smann419
09-30-2008 07:15 PM
ovlov96
06-04-2008 09:00 PM
Quick Reply: Turn signals and parking flashers not working! Checked fuses and bulbs...
