turboxs rbv-25
turboxs rbv-25
is it ok to run stock psi with this bypass, or do you need a boost controller or upgrade turbo, the reason i ask is that it says psi range is from 10-25 and i beleive the a4 (b6) is 7 or 8, but correct me if im wrong
RE: turboxs rbv-25
ORIGINAL: rummy
uhhh.....uh, yea...um....what is your question, if its a bov, no you cant run it..your motor will fall out of the car and your turbo will turn into a drill and your tires will start on fire.
im sorry i have to be the bearer of bad news...but its ok. you are ok.
RE: turboxs rbv-25
omg really it will fall out, why will it fall out ahahahahahahahahah thats the dumbest reply its a yes or no question and i searched it foo and there was nothing on it, it had no use for a dumbass comment fool
RE: turboxs rbv-25
so did you miss the part where he said it was ok???
ORIGINAL: rummy
RE: turboxs rbv-25
wow what retard would ask about bov's and then follow up and say he actually searched for it and didnt come up with anything? JESUS. Heres the writeup i made alittle while ago all the info you will need on what your looking for.
https://www.audiforums.com/m_246485/tm.htm
DrZacharyus
02-21-2009 03:05 PM
TTinNC
12-17-2006 10:14 AM
