TURBO XS HP boost level adjustment
I was looking for some user expierence with the TURBO XS HP MBC. I read that the boost level adjustment is made by turning two screws with a hex key or something. How is this to use? There are many MBCs that have a **** on the end which seems to be easier to adjust, but i cant find one that is combo bleed/ball and spring that i am looking for. Is it difficult to set the boost where its not spiky with the tandom adjustment *****?
barrett
barrett
RE: TURBO XS HP boost level adjustment
ORIGINAL: chaos92287
you cant crank up the boost past what the MAF can correct or you will run lean and fvck your engine up...i coulda sworn i answered this thread already...weird
barrett
Here is mine installed
Best mbc you can by imho. The broze fitting is the ball&spring and the blue end is the bleed valve. You adjust it with a hex/allen key so it cant change while driving or hitting anything. its simple to install and set. Basically for a smooth boost onset, you will set the b&s to about 2-3psi less than target boost and then up the remaining psi with the bleed. With the combination you can get fast spool (b&s) and smooth boost onset (bleed). Let me know if you need any help
