turbo trouble
Old 11-25-2004 | 03:30 AM
thintzen's Avatar
Default turbo trouble
when changing the turbo on the a4, do i have to change the manifold gasket? i'm asking because my turbo is heating up, and actually glowing red by the wastegate area. does anyone think thati have to flush the coolant or anything?
Old 11-25-2004 | 04:21 AM
awol's Avatar
Default RE: turbo trouble
How many miles are on your car? Glowing can be caused by a bad CAT!
Old 11-25-2004 | 04:24 AM
King_D's Avatar
yeah a bad cat will make your turbo glow significantly
Old 11-25-2004 | 04:37 AM
thintzen's Avatar
80k..the turbo unit is new i had just installed it tonight..right out of the box
Old 11-25-2004 | 04:40 AM
King_D's Avatar
K04?
Old 11-25-2004 | 04:45 AM
thintzen's Avatar
i had the ko4 runningon the stock 98 parts and had the problem, so i decided to go back to the k03, and its still happening. it didnt happen witht he old k03 i removed..its only starting to happen now
could it be my coolant line is clogges, or something needs to be flushed
wheh i give the car time to cool down by idleing..it goes away
only when i drive hard
Old 11-25-2004 | 04:29 PM
King_D's Avatar
theres your problem dood. switch back to the K04. If not e-mail me David_Kersch@hotmail.com
Old 11-25-2004 | 07:20 PM
audiboy1618's Avatar
Dave, is it really good on a engine to run a ko4 on stock software. I would think there would be shortages of air/fuel?
Old 11-25-2004 | 09:00 PM
King_D's Avatar
no its fine. you will actually get better gas mileage because the K04 flows so much better than the K03. well gotta go. gotta spend thanksgiving with the fiancee (good) and her parents (bad) especially when the figured out were living together.
Old 12-20-2004 | 03:24 AM
thintzen's Avatar
should i get a turbo timer for my stocl k03?
