Sponsored by:
Sponsored by:
tt injectors with pc-15 and 5 bar fpr?
Old 11-10-2005, 10:34 AM
juju4uofa's Avatar
Default RE: tt injectors with pc-15 and 5 bar fpr?
With the e05 you can not use the larger injecters. The file was written for stock injectors. If you go with GIAC you can use the regular K04 software for a while and then upgrade to the PC-16 file for a discount. With the PC-16 you'll need the 310cc injectors and a 3bar adjustable FPR set at about 2.7-2.8bar.
You will mess things if up if you start playin with pc-16 and not know what ur doing. You cant just toss in inj/fpr and ur done. Then its time to tune it.
Audiboy, what exactly do you mean by "you'll have to tune it". Isn't that what the software is for? I know you'll have to play with the adjustable FPR to get the right air/fuel ratio, is this what you mean?
yes the TT/Jetta ones will work with the j31/pc-16
Not that you're wrong but I know I've heard that for whatever reason you weren't supposed to use TT injectors. Maybe the source was incorrect or I just misunderstand. Can someone else verify this. Also, Jetta injectors? Or they any larger than stock A4 injectors anyway?
Old 11-10-2005, 11:02 AM
clconversion's Avatar
yes probley more people are running the J31/PC-16 with TT/Jetta same part # for the 180hp model
george1546
05-05-2013 06:57 AM
xxipsxx
12-11-2010 03:13 PM
TeeterTawter
05-18-2008 01:01 PM
pa4ul
05-03-2008 02:43 PM
MC Hammered
02-04-2008 12:06 AM
Quick Reply: tt injectors with pc-15 and 5 bar fpr?
