trouble shooting question on my audi
Old 03-20-2006 | 03:46 AM
trailboss's Avatar
Default RE: trouble shooting question on my audi
ORIGINAL: audiguy00
also i am thinking about running a k04. can i use my apr 93 chip for that?
bobby
i will need a fpr though right?
You can run a k04 on the software but it will not be tuned right. Best bet is to get GIAC software for the ko4. The k05 giac file runs a 5 bar fpr, so i wouldn't even mess with the fuel pressure if you are gonna run it on Aprs k03 file.
Also look into different plugs, NGK Bkr6e's gapped at .028"-.030", they are pretty darn good and cheap <$2.00, alot of people that ran denso's didn't like them that much, especially the iridium plugs.
Old 03-20-2006 | 03:48 AM
trailboss's Avatar
also check for boost leaks, they also will tend to do what you described spike to the desired psi, and then the boost fades.
Old 03-20-2006 | 06:20 AM
audiguy00's Avatar
thanks a lot trailboss! so i got that question out of the way! you guys are being a great help! how bad is it to run a k04 with my apr software... like what is the worst that can happen? i know i wont make as much power as it should. but anything else?
and no one has ever run into a speeometer and gas gauge acting up like i have described in the top?
thanks for all the help
bobby
oh and the car just started making a new noise too... wow this is getting bad... i need to take it out of commission soon and get this all fixed. the noise is liek a chirping noise on take offs when letting the clutch out... it moans or something. like a bad mount or what ever... anyone ever run into a noise on taking off and letting the clutch out?
sorry bout all the questions...
gives all you smart guys a chance to show off a little by helping the stupid guy who used to own hondas.
Old 03-20-2006 | 11:31 PM
trailboss's Avatar
For the software part, its kinda hard to say some people have run it on the software for a while then upgraded software. If you do run it on the APR software i would get a VAG-com and do some logging to make sure you don't blow **** up. The way i do things or at least try to, is make sure i have everything necessary to do the install. You can always sell you APR chip and have some money for a new one, someone would buy it.
Speedometer to stop working that is either a wheel speed sensor or loose conection somewhere
Gas gauge, alot of people have this problem, its a fairly easy fix but takes some time. The sending unit normally fails, but it is on top of the gas tank so you gotta drop the tank. There is a writeup i think, i know Jestnomen on here has done one. Best to do this on an empty tank.
As far as the noise when you get out of gear, wheel bearings will start to make a humming, moaning sound when they start to fail. If its a chirping sound only when you get out of gear then im not sure, kinda hard to say. You can check the wheel bearings by lifting the car and trying to push or pull the wheel from the top or bottom of the wheel.
Hope Im of some help, maybe someone else can chime in too.
a4audia4
12-16-2012 01:11 PM
downbytheriver
11-01-2012 09:02 PM
jhowerter
09-06-2012 09:23 PM
DoubleFace
04-25-2008 04:06 PM
The Russian
03-06-2007 03:26 AM
