tire/wheels and suspension work
Hi everyone
I have plans to switch tires and wheels on my A4 3.0 base as well as lower the suspensions with the right set of springs.
Here are my dilemas on which I am looking for some experienced suggestions.
I want the final suspension work to be a linear look (not higher in the rear like the factory one) and I HAVE TO STAY AWAY FROM Coil-Overs DUE TO BUDGET. The problem is that the Eibach and H&R springs I've seen so far provide the same "drop" level in the front and rear which will result in a slighly higher rear, i.e. just like it is now but lower. I came into this manufacturer called H-Sport that makes a set that gives a 1.0" F and 1.1" R drop.
1. I need a lower drop than just 1", any suggestions?
2. Is anyone familiar with H-Sport springs? How do they perform?
3. What do you think of 18x8 wheels compared to 19x8.5?
Thanks
Thanks
RE: tire/wheels and suspension work
1. 1" will still give you wheel well clearance. if you want an even drop, CO's are the best way to go.
2. I know H-sport makes good sway bars. not sure about the springs.
3. I'm assuming you have a B6. IMO, 18's or 19's, the look of the wheel will make your car complete. you can't really go wrong with either size.
