Tiptronic shift issue
My A4 Avant seems to shift twice in second gear. When I put it in second, it begins to accelerate, then seems to shift a second time while still in second. RPM's drop and then pick up again.
Only does this in 2nd
Any suggestions as to what this is?
RE: Tiptronic shift issue
I know EXACTLY what you mean. Its a very good question. Not a delay... I think it has to do with the tq converter locking up a little too soon and then when you give it more gas it lets go like it is shifting up again. I seem to only notice this on turns in tip mode when i manually switch from 3rd to 2nd gear and not driving aggressive... Sound familiar???
ORIGINAL: eurokid
get it fixed with a chip* that's what i did
I think I know what you're talking about. It happens to me also, only in 2nd gear.
For instance, if I do a rolling stop at a stop sign (in Tip mode, not automatic) and leave it in 2nd gear.....so I'll be at 5mph in 2nd gear....as I accelerate, right around 2.5K RPMs, the revs will drop off suddenly, about down to 1K, then climb back up through 2nd gear.
If this is the case, it's definitely not just you.
RLGarage, do you have a 1.8T or a 2.8 V6?
If you have a V6, this could this the "dead spot" that all the V6 people complain about. I thought it had to do with torque a little higher in the gear, but I could be wrong...never had a great understanding of the "dead spot" people referred to. But from what I understand, the "dead spot" is one of the few things that the GIAC engine chip (ECU) will improve with our engines. (aside from 5-8 HP, and removing the rev limiter).
^ Your description sounds a little more exagerated than mine. Mine may drop a couple hundred rpms and then make its way back up, but same gear and speed etc. and its only when im coming to a rolling stop and then get back on the gas at low speed, like in a turn. And only if im lightly gasing it. If I press the gas down 1/2 way after i complete the turn it doesnt do it.
I think the dead spot issue people have with the 2.8 happens mostly around 3k rpms.
ORIGINAL: Amze
Ohhh god, Onepoint8tee you dont drive auto do you..?
